Part Number: BQ24800
Hello, i am not sure if this is the correct place to ask this, but i have an Asus ROG Zephryus g14 401Q that has a problem. The battery connector shorted when being disconnected and after removing and examining the entire motherboard, i found the chip slightly to the right of the connector had a small burn mark on the top of it, this chip says the following on it:
BQ
24800
TI 158
AP (cant read due to burn)
I was hoping to be able to order this chip so i can repair it, i cant afford to have it professionally repaired and I cant seem to find the proper chip anywhere. Thank you.
