Part Number: BQ25710
HI Team
I would like confirm BQ25710 adapter only set recommend from TI ?
When adapter only we need make sure adapter can't trigger adatper OCP.
1.Which register we should follow to set ?
2.When we disable IDPM the charger input current will follow the external current limit right ?
Thanks
Louis Lo
