BQ76907-Q1-DESIGN: BQ76907: I2C communication issue
Part Number: BQ76907-Q1-DESIGN
Issue description:
When using Subcommands to write registers, first write 0x3E, and then immediately execute the next instruction, there will be a bus stuck state.
   Observation:
      The clock signal remains low, Afe does not release the bus
   Root cause: Insufficient waiting time for executing two-step operations by Subcommands, resulting in bus stuck
   Support: To confirm how long it takes for Subcommands to wait between executing the two steps, Could you please provide a definite value ?
Thankyou
