BQ24072: BQ24072 IEC 62368-1 Compliance Certificate
Part Number: BQ24072
I am currently designing a product and facing a compliance challenge. During testing, we are required to short the input and output to bypass the BQ24072, resulting in current levels that exceed the specified limits. Could you please provide the IEC 62368-1 certificate for the BQ24072? We require this document to request a waiver for this specific test.
  • Hello, we have received your case and the investigation will take some time. Thank you for your patience.
  • Hi,
    TI forums are designed to address technical issues that customers encounter when using TI products. We recommend that you contact Customer Support as follows and a customer service will be available to assist you.
    •Open the link ticsc.service-now.com/csm
    •Click on the “Submit a request” button under “Request new support”
    •Click on Quality in the newly opened window Reliability and environmental information
    •In the form that opens, you can describe your problem and submit it.
