Part Number: TPS53685
Hi, Sir
Could you supply which controller & SPS or TLVR solutin (Pin to Pin) as RAA221497 & RAA228926 of RENESAS or the other multi phase solution for data center use.
Do you have contact window of Taiwan FAE?
Thank you.
Hi, Sir
Thank you.
TI does not have a pintopin replacement. In this category, we have screened the following models for you, and you can ask your technical staff to see if any of these chips are suitable for your project.
