bq33100芯片中的【RSOCL】bit在Operation Cfg中的那个位上?
Other Parts Discussed in Thread: BQ33100
在bq33100的数据手册上写着:
If  the  [RSOCL]  bit  in  Operation  Cfg  is  set  then  RelativeStateofCharge  is  held  at  99%  until  primary  charge termination occurs and only displays 100% upon entering primary charge termination.
但是,在数据手册中显示 Operation  Cfg寄存器中并没有这个 [RSOCL] 位。请问,这个 [RSOCL] 位在哪?是不是被“RSVD”了?
