我在项目中用到了BQ24195,通过STM32单片机的I2C读写寄存器,现在发现我可以正常的读寄存器的值,但我如果设置寄存器时,设置相关寄存器后读取的话显示是0,过一段时间后显示为默认值,无论CE脚设置是高电平或低电平。
你好!
我的部分代码如下:
CE_POWER = 0;
delay_ms(2000);
slave_addr = 0x6B;reg_addr = 0x1;data_addr = 0x2b;
i2c_write_sreg(slave_addr,reg_addr,data_addr);
delay_ms(500);
reg_data = i2c_read_sreg(slave_addr, reg_addr) ;printf("0x%02x ",reg_data);
delay_ms(500);
unsigned char i2c_read_sreg(unsigned char slave_addr, unsigned char reg_addr)
int i;
unsigned char t;
unsigned char reg_data;
i2c_start();
t = (slave_addr << 1) | 0;
i2c_write_byte(t);
i2c_write_byte(reg_addr);
i2c_start();
t = (slave_addr << 1) | 1;
i2c_write_byte(t);
//i2c_write_byte(reg_addr);
reg_data = i2c_nread_byte();
i2c_stop();
return reg_data;
void i2c_write_sreg (unsigned char slave_addr, unsigned char reg_addr, unsigned char reg_data)
int i;
unsigned char t;
i2c_start();
i2c_write_byte(t);
//i2c_write_byte(slave_addr);
i2c_write_byte(reg_data);
i2c_stop();
return;
你好!
我的部分代码如下:
CE_POWER = 0;
delay_ms(2000);
delay_ms(500);
delay_ms(500);
int i;
unsigned char t;
i2c_start();
i2c_write_byte(t);
i2c_start();
i2c_write_byte(t);
i2c_stop();
return reg_data;
int i;
unsigned char t;
i2c_start();
i2c_write_byte(t);
i2c_stop();
return;
