Other Parts Discussed in Thread: BQ24040
5.4V输入给3.7V充电,输入一直存在,电池一直接着。充满电后,电池电压随着时间的推移会下降,降到一定值后会自动充电吗?
理论上是的:
A new charge cycle is started when a good power source is applied, performing a chip disable/enable (TS
terminal/BAT_EN), exiting Termination and Timer Disable Mode (TTDM), detecting a battery insertion or the OUT
voltage drop below the VRCH threshold.
我的意思是输入一直在,电池充满电后,放电放到一定值会自动补充吗,还是要拔一下输入才可以再次冲电
