Other Parts Discussed in Thread: BQ40Z50
周末在家看手册是时候,被这个QMAX搞得迷迷糊糊 的,
The bq40z50 updates the no-load full capacity (QMax) when two open circuit voltage (OCV) readings are
taken.
Measurements of OCV and charge integration determine chemical state-of-charge and Chemical Capacity
(QMax)
上面两段中都有解释,但不一样,不知道该怎么理解,
还有电池容量扩大,除了修改,design capacity 和QMAX cell 0 1 2 3 以外,要不要改电池的阻抗,,还有手册里面有一个词 Ra 是该怎么解释?
