上传计算CHEM ID很多次了,一直修改,都出现错误,附件是我的LOG数据,可否帮忙看一下或则计算一下。
你好,改过了,重新上传,还是报错,附件是我改过的,请您帮我看一下,还有哪些错误,实在找不出有错的地方了
Thank you for your interest in the Gauging Parameter Calculator from TI. Please find attached the Gauging Parameter Calculator report that was based on your Gauging Parameter Calculator input zip file submission.
This completes the Gauging Parameter Calculator process. Should you want to re-submit or need assistance with Gauging Parameter Calculator, please reference the sites below:
• Visit TI E2E™ Community on Battery Fuel Gauges or the Gauging Parameter Calculator.
• TI Battery Management Homepage
Thank you for using TI's Gauging Parameter Calculator for Battery Fuel Gauges.
