BQ27541提交TI网址做阻抗高低温优化问题
Other Parts Discussed in Thread: BQSTUDIO
请教下,我现在用BQ27541做了室温和低温(-40℃)的充放电试验,也记录了数据,但提交到GPC计算了,返回了如下错误信息,TI的技术或知道的同事帮忙解决一下,谢谢!
提交和返回的压缩包数据在附件,劳烦看一下。
错误信息如下:
Due to GG file format issues, GG values have not been updated
Warning: Automatic firmware properties detection failed. Rb_select defaults to 2. Please make sure that chem ID loaded in the GG file is the same as ID specified in the config.txt
Warning: Automatic firmware properties detection failed. basescale defaults to 1. Please make sure that chem ID loaded in the GG file is the same as ID specified in the config.txt
Warning: dod0 too large in low. temp. file     dod0=0.228609336912586 usually caused by absense of relaxation
Warning: dod0 too large in room. temp. file     dod0=0.147113281544099 usually caused by absense of relaxation
