如题,小弟刚接触电路不久,参照PMP4496 中的设计,成功地完成PCB 以及贴片的工作,接上电池后发现 ,板子并不工作,MSP430G2332 中缺少程序。求各位大神老师,可否为小弟提供一下,感激不尽。rindybin@126.com
Please refer to the demo code attached. Reminder, it's only for reference, please revise it before you release it to production.
By the way, please build “Release Version”, otherwise would fail due to not enough code space.
DISCLAIMERS
Export Control Classification Number (ECCN)
Any use of ECCNs listed in the Manifest is at the user’s risk and without recourse to TI. Your company, as the exporter of record, is responsible for determining the correct classification of any item at the time of export. Any export classification by TI of Software is for TI’s internal use only and shall not be construed as a representation or warranty regarding the proper export classification for such Software or whether an export license or other documentation is required for exporting such Software.
Links in the Manifest
Any links appearing on this Manifest (for example in the “Obtained from” field) were verified at the time the Manifest was created. TI makes no guarantee that any listed links will remain active in the future.
Open Source License References
Your company is responsible for confirming the applicable license terms for any open source Software listed in this Manifest that was not “Obtained from” TI. Any open source license specified in this Manifest for Software that was not “Obtained from” TI is for TI’s internal use only and shall not be construed as a representation or warranty regarding the proper open source license terms for such Software.
Export Information
ECCN for Software included in this release: Publicly Available
ECCN for Technology (e.g., user documentation, specifications) included in this release: Publicly Available
Manifest
See Legend above for a description of the columns and possible values.
Software Name
Version
License Type
Delivered
As
Modified by
TI
MSP430TCH5E_Code_Examples
1_00_00_00
BSD_EX
Source
Texas Instruments
Location
[installed path]/MSP430TCH5E_Code_Examples
Obtained from
Texas Instruments
Credits
Licenses
Copyright (c) 2013, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
MSP430 CODE EXAMPLE DISCLAIMER
MSP430 code examples are self-contained low-level programs that typically
demonstrate a single peripheral function or device feature in a highly
concise manner. For this the code may rely on the device's power-on default
register values and settings such as the clock configuration and care must
be taken when combining code from several examples to avoid potential side
effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
for an API functional library-approach to peripheral configuration.
编译时请选择 “Release Version”, 否则显示内存不够。
在CCS项目设置,Build Configuration -->Set Active --> 2 Release.
