關於設定CEDV 要上交的參數關於這幾項小弟實在看不懂,請指教
• VoltageColumn = <Zero based column number for the voltage data in your data logs>
• CurrentColumn = <Zero based column number for the current data in your data logs>
• TemperatureColumn = <Zero based column number for the temperature data in your data logs>
• ElapsedTimeColumn = <Zero based column number for the elapsed time data in your data logs>
• FitMaxSOC% = <Integer ranging from 8 to 14. Typical is 12>
• FitMinSOC% = <Integer ranging from 2 to 6. Typical is 6>
• LearnSOC% = <Integer ranging from 5 to 12. Typical is 7>
