计算CHEM_ID的MATHCAD程序无法下载。
Other Parts Discussed in Thread: GPCCHEM, BQSTUDIO
MATHCAD程序按照文档里给的链接无法打开,下载不了。技术支持可以发给我一份吗?
  • Hi
        将文档和链接发上来一下。
  • 可以使用网上的工具GPCChem。把log数据按照相应的格式处理好,打包成.zip文件上传,服务器一会就把结果发到你的邮箱里。
    http://www.ti.com/tool/gpcchem
    GPC Chemistry ID matching for Impedance Track (IT) algorithm gas gauges (Find closest chemistry match) must be done before Optimizing room temperature or low temperature performance.
    Gauging Parameter Calculator Chemistry ID matching for Impedance track gas gauges (GPCCHEM) is a math calculation and simulation tool that helps the battery designer to obtain matching chemistry ID for the specific battery profile. Chemistry IDs are defined by Texas Instruments and can be programmed using Battery Management Studio (bqStudio). The GPCCHEM tool allows the user to increase the accuracy of the fuel gauge IC.
  • 这个方法虽然可行,但我这里不能上网,所以就不能把我的数据打包上传吧?
