请教BQ24075和BQ24075T的区别
Other Parts Discussed in Thread: BQ24075, BQ24075T
请教TI的哪位高手,
TI的BQ24075和BQ24075T的区别在什么地方,对应用有哪些影响,谢谢!
  • Hi
         BQ24075  uses a current source to drive the NTC Thermistor connected to the TS pin.  The bq24075T uses a voltage source to drive the NTC Thermistor connected to the TS pin.  The end result is the same however, the voltage source gives you more flexibility.  The the voltage based TS (T version) allows the user to scale the thermistor to use any value 10k, 100k, 50k, where as the current version only uses the 10k NTC at 25C.
