这是我上传给TI的数据,用来测CHED-ID!!
但TI回复我的内容如下,想请问下问题出在哪里??
Best chemical ID : 300 Best chemical ID max. deviation, % : 30.94
Summary of all IDs with max. DOD deviation below 3%
Chem ID max DOD error, % Max R deviation, ratio
0 0 0
Accuracy Error: Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule
CS.zip
