BQ501210 I have problems in this wireless charge manage IC's usage?
Other Parts Discussed in Thread: BQ501210
I want to control the chip(BQ501210)  via  the j-tag interface.May i get the programming software,simulation device and programming manual?
  • Hi,
    It can be controlled by PMBus, you can use a USB to GPIO adapter to program this chip. software name is GUI, you can download it from link here
    http://www.ti.com/tool/fusion_digital_power_designer?keyMatch=GUI&tisearch=Search-EN-Everything&rec=true
    For programming, you can check that in datasheet, which can be found from ti.com.
    Thank you
