3串电池如何填写计算chemid压缩文件.zip
别人的都是1串,我是3串的
帖子上看到的格式是:
ProcessingType=2
NumCellSeries=1
ElapsedTimeColumn=3
VoltageColumn=9
CurrentColumn=15
TemperatureColumn=8
问:上面的意思都懂,主要是NumCellSeries=3,之后电压电流怎么写?电压电流写电池包的还是单个的呢?
  • 大家帮忙看下
    上传压缩文件后出现的错误如下,提交的文件在附件里,帮忙看下数据是哪里不对,我的电池是3串,提交的选项是时间,总电压,总电流,温度。谢谢~:
    The following errors were reported by the calculation engine:
    Accuracy Error: Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule
    fin_report.zip
  • 电压和电流指的是在excel中电压数据和电流数据所处于的列,你的excel中在第几列,就写几
