DC/DC MOSFET Current limit
Other Parts Discussed in Thread: TPS54620
Does the minimum of High-side switch current limit and Low-side switch sourcing current limit decide the output inductor peak current?
For example,in TPS54620 datasheet, High-side switch current limit and Low-side switch sourcing current limit are 11A and 10A respectively, does that mean the output inductor paek current can reach no more than 10A?
