BQ501210的FOD调试,有4个脚与FOD相关,19 脚FP_GAIN :Output to select the FOD ping calibration gain, 20脚 FP_OFFSET : Output to select the FOD ping calibration offset , 22 FOD_CAL: Output to select the FOD calibration; 23 FOD : Output to select the foreign object detection (FOD) threshold 按规格书配置这四个脚的外接电阻,并按规格书table1,FOD 门限配置表格调整门限电阻,效果不理想。请问其他3个脚的电阻应该怎么配置?
