TI公司的技术人员你们好!
我是一名新手,我在网上看到了UCC3895这一款芯片,所以就接了出来试一下,电路是成功了,但是我调节EAP脚的输入电压,它的波形没有发生变化,就是输出还是50%。我想问一下,电压模式的接线是如何接的。能不能给个好的电路出来。
TI company's technical staff you good!
I am a novice, I see on the net of the UCC3895 chip, so take a try, the circuit is successful, but I adjust the EAP pin input voltage waveform, it has not changed, the output is still 50%. I want to ask once, voltage mode wiring is how to answer. Can you give a good circuit.
