hello,
我们现在在做一个电量计,要求低温工作环境为-40℃,根据网站提供的信息,需要做低温电量优化。请问一下,在通过一次充放电数据确定Chem ID后,就在低温环境下进行放电优化,然后在进行循环学习?还确定Chem ID后,进行循环学习,之后再进行低温下的放电优化呢?
hello,
hello,
我按照要求,做了ChemID选择;常温循环学习。然后做了低温下的放电,把数据提交到TI网站后出现如下错误,请问该怎么处理呢?
hank you for your interest in the Gauging Parameter Calculator from TI.
There was an error in processing your report. The specific error encountered is:
The following errors were reported by the calculation engine:
Error: Ra table could not be extracted from GG file. Make sure that chem ID was freshly programmed and no learning took place. Flags ff55 or ffff should be present 0
Please see the Gauging Parameter Calculator for information about the file format and the procedure for creating the input zip file. Should you want to resubmit or need assistance with the Gauging Parameter Calculator, please reference the sites below:
Thank you for using TI's Gauging Parameter Calculator for Battery Fuel Gauges.
上传的gg文件需要是学习前的gg文件,不要上传学习后的gg文件。
