Battery Management Studio 开启遇到错误 不能正常使用 an error has occurred see the log file
Other Parts Discussed in Thread: BQSTUDIO
!SESSION 2018-07-28 10:28:48.640 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_74
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-07-28 10:29:12.984
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
java.lang.UnsatisfiedLinkError: C:\ti\BatteryManagementStudio\sdkjniadapter.dll: 由于应用程序配置不正确,应用程序未能启动。重新安装应用程序可能会纠正这个问题。
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at toolsSDK.JNIWrappers.SDKLib.<clinit>(Unknown Source)
at com.ti.evswsdk.communication.connection.CMConnection.<init>(Unknown Source)
at com.ti.evswsdk.communication.connection.CMConnection.getInstance(Unknown Source)
at com.ti.evswsdk.ApplicationWorkbenchWindowAdvisor.preWindowOpen(Unknown Source)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(WorkbenchWindow.java:1654)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:654)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:86)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1526)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1500)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:944)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:138)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:704)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1266)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1112)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1122)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1673)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2193)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4673)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1633)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2117)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5050)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:230)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1244)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:694)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:658)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1057)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at com.ti.evswsdk.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
!ENTRY org.eclipse.osgi 4 0 2018-07-28 10:29:13.203
!MESSAGE Application error
!STACK 1
!ENTRY com.ti.evswsdk 4 0 2018-07-28 10:29:13.468
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in com.ti.evswsdk.Activator.stop() of bundle com.ti.evswsdk.
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:847)
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:955)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:323)
at org.eclipse.osgi.container.Module.doStop(Module.java:626)
at org.eclipse.osgi.container.Module.stop(Module.java:488)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1623)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1542)
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:248)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:144)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:186)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:159)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class toolsSDK.JNIWrappers.SDKLib
at com.ti.evswsdk.Activator.stop(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:827)
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:820)
... 13 more
Root exception:
!SESSION 2018-07-28 10:29:30.281 -----------------------------------------------
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-07-28 10:29:46.546
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2018-07-28 10:29:46.843
!STACK 1
!ENTRY com.ti.evswsdk 4 0 2018-07-28 10:29:47.093
!STACK 0
... 13 more
Root exception:
!SESSION 2018-07-28 10:45:23.984 -----------------------------------------------
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-07-28 10:45:34.843
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2018-07-28 10:45:35.000
!STACK 1
!ENTRY com.ti.evswsdk 4 0 2018-07-28 10:45:35.156
!STACK 0
... 13 more
Root exception:
!SESSION 2018-07-28 10:45:50.953 -----------------------------------------------
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-07-28 10:46:01.656
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2018-07-28 10:46:01.812
!STACK 1
!ENTRY com.ti.evswsdk 4 0 2018-07-28 10:46:01.968
!STACK 0
... 13 more
Root exception:
!SESSION 2018-07-28 10:50:12.375 -----------------------------------------------
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-07-28 10:50:23.000
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2018-07-28 10:50:23.171
!STACK 1
!ENTRY com.ti.evswsdk 4 0 2018-07-28 10:50:23.343
!STACK 0
... 13 more
Root exception:
