bq27542-g1 Error: negative low temperature resistance observed
Other Parts Discussed in Thread: GPCCHEM
HI ALL:
    使用BQ27542-G1 用GPC做低温补偿时,反馈说是低温的电阻为负值,问题如下.
   The following errors were reported by the calculation engine:
   Error: negative low temperature resistance observed, R=-1.61973095533587 usually caused by wrong chem ID selection 0 0
不知道是什么问题,
看有谁能帮我解决.
化学ID:0188
上传的zip文件:4024.bq27542g1-temp_compensation.zip
