BQ78350请帮忙看下 CEDV 数据有何异常?计算不成功
Genius 3755 points
Your Gauging Parameter Calculator report is here.
Thank you for your interest in the Gauging Parameter Calculator from TI.
There was an error in processing your report. The specific error encountered is:
Error: Computation was not successful, but the specific reason was not identified.
       Please check that all files are prepared according to the documentation.
       The support personnel have been informed
Please see the Gauging Parameter Calculator for information about the file format and the procedure for creating the input zip file. Should you want to resubmit or need assistance with the Gauging Parameter Calculator, please reference the sites below:
• Go to Gauging Parameter Calculator to re-submit.
• Visit TI E2E™ Community on Battery Fuel Gauges or the Gauging Parameter Calculator.
• TI Battery Management Homepage
Thank you for using TI's Gauging Parameter Calculator for Battery Fuel Gauges.6082.CEDV2.zip
