TPS65218x不推荐在新设计中使用,替代的TPS65218D0在使用是有什么不同
Other Parts Discussed in Thread: TPS65218D0, TPS65218
在使用AM347X的电源管理时,要使用TPS65218D0的话,要进行哪些修改,程序上与电路上都要进行修改么
旧设计中可以直接替换么
  • 你好,
    Simply put, the TPS65218D0 is a device that is functionally equivalent to the TPS65218 (-B1 version) that meets the majority of the original target specs of the device. They are pin-2-pin compatible and functionally equivalent. The TPS65218D0 is replacing the -B1 version, and they are a not complementary devices. 差别不大。可以先不改试试,谢谢。
