请帮忙看一下CDEV的放电试验数据格式哪里有问题?谢谢!
Genius 3755 points
Other Parts Discussed in Thread: GPCCHEM
Thank you for your interest in the Gauging Parameter Calculator from TI.
There was an error in processing your report. The specific error encountered is:
There was a problem with the content of the zip file.
  • Invalid Zip File Member - 0deg_20A_DSG.csv
  • Invalid Zip File Member - 0deg_7A_DSG.csv
  • Invalid Zip File Member - 25deg_20A_DSG.csv
  • Invalid Zip File Member - 25deg_7A_DSG.csv
  • Invalid Zip File Member - 50deg_20A_DSG.csv
  • Invalid Zip File Member - 50deg_7A_DSG.csv
  • Required file 'roomtemp_rel_dis_rel.csv' is missing from the input zip file.
Please see the Gauging Parameter Calculator for information about the file format and the procedure for creating the input zip file. Should you want to resubmit or need assistance with the Gauging Parameter Calculator, please reference the sites below:
• Go to Gauging Parameter Calculator to re-submit.
• Visit TI E2E™ Community on Battery Fuel Gauges or the Gauging Parameter Calculator.
• TI Battery Management Homepage
Thank you for using TI's Gauging Parameter Calculator for Battery Fuel Gauges.8420.GPCCHEM_GPC_TBMS_LIPO_V10.zip
  • 文件名错了
    hightemp_highrate.csv
    hightemp_lowrate.csv
    roomtemp_highrate.csv
    roomtemp_lowrate.csv
    lowtemp_highrate.csv
    lowtemp_lowrate.csv
  • 不是说名字不重要的吗?一定要已这个名字为准?
  • Thank you for your interest in the Gauging Parameter Calculator from TI.
    Invalid Zip File Member - hightemp_highrate.csv
    Invalid Zip File Member - hightemp_lowrate.csv
    Invalid Zip File Member - lowtemp_highrate.csv
    Invalid Zip File Member - lowtemp_lowrate.csv
    Invalid Zip File Member - roomtemp_highrate.csv
    Invalid Zip File Member - roomtemp_lowrate.csv
    这又该说什么呢?
  • 你到底有没有看过数据哦?
  • www.ti.com/.../sluub45b.pdf
    这个文档说的很清楚,压缩文档有7个文件,一个config.txt文件,6个文件就是我上面发的文件。
    不用看您的数据,您的文档名字就错了。回复您的信息里有说明没有找到roomtemp_rel_dis_rel.csv
  • 对,一共7个文件!一个config.txt文件 ;6个文件Invalid Zip File Member - hightemp_highrate.csv
    信息里有说明没有找到roomtemp_rel_dis_rel.csv,这是个什么文件?
