78350 CDEV 计算不成功,报告如下,请帮忙分析
Genius 3755 points
Other Parts Discussed in Thread: GPCCHEM
Your Gauging Parameter Calculator report is here.
Thank you for your interest in the Gauging Parameter Calculator from TI.
There was an error in processing your report. The specific error encountered is:
Error: Computation was not successful, but the specific reason was not identified.
       Please check that all files are prepared according to the documentation.
       The support personnel have been informed
Please see the Gauging Parameter Calculator for information about the file format and the procedure for creating the input zip file. Should you want to resubmit or need assistance with the Gauging Parameter Calculator, please reference the sites below:
• Go to Gauging Parameter Calculator to re-submit.
• Visit TI E2E™ Community on Battery Fuel Gauges or the Gauging Parameter Calculator.
• TI Battery Management Homepage
Thank you for using TI's Gauging Parameter Calculator for Battery Fuel Gauges.
To ensure delivery to your inbox, please add gpc_do_not_reply@ti.com to your address book or safe sender list.
The platform bar is a trademark of Texas Instruments. All other trademarks are the property of their respective owners.
0724.GPCCHEM_GPC_TBMS_LIPO_V10.zip
