BQ78350和BQ76930方案,电池电量显示,电池的ID库里面找不到,ID的学习是必要的吗?
match the voltage vs capacity profile which will be stored in the gauge (bq78350-R1) for capacity estimation after reset
如果没有对应的,您可以通过GPCCHEM tool 计算一个ID
