我在做BQ40Z50r1的电池学习,前面都是按照操作步骤做的。选化学ID,配置参数,校准,reset,放电至3V左右间隔5小时,打开GAUGE_EN,充电至FC置位,间隔两小时;放电至3V左右(FD置位了)。但是QMX就是不更新,Ra_flag就只更新到0555,再做一个循环还是这样。我注意到放电快结束的时候RDIS置位了,间隔五小时后有消除了。
请问这是怎么回事呢? 是我设置有问题吗?谢谢指点!
Did you tweak the deadband or cc deadband? If yes, please change them back to defaults. For proper charge termination, I suggest that you let your current drop to about 80mA for at least 100 seconds before stopping current. The best way to charge terminate is to have the CHGFET option turned on in the registers. That way the charge fet will turn off on charge termination.
您参考下面这个文档帮助您learning
www.ti.com/.../slua777.pdf
