BQ25703 register configuration and power-down issues
BQ25703 register configuration and power-down issues:
After the BQ25703 is configured with voltage / current parameters, if the system is powered off and the battery is exhausted, does the BQ25703 need to be reconfigured after the system is powered on? Will the original configured voltage / current parameters be retained?
Looking forward to reply, thank you!
