How could I disable ovp function on TPS25942ARVCT?
Hi, as title.
Last week i went to the laboratory and test my product about EFT NOISE.
I mix 2KV 100KHZ EFT noise into 220V AC CABLE and found that this IC will open the power circuit, and my product shut down instantly.
At present my guess is that the OVP is enabled, so the IC leaves the power circuit open.
I want to confirm that ovp is enable? and how to turn off this feature.
上周我去實驗室測室
我在AC 220V中混合2KV 100KHZ的EFT雜訊,發現會會讓這顆IC開路,我產品就瞬間關機。
目前我的推測是OVP啟動,所以IC就讓電源開路。
想確認是否如此,以及要如何關掉這個功能。
220V是指供給adapter 轉15V DCV , 我們產品是吃15V.
