在测试BQ4050短路的时候,出现了如下情况:
当电池包静止一段时间(使电池包进入睡眠状态),这个时候做直接短路测试,发现短路会出现短暂恢复的情况。
如果接上通讯来测试,则没有这种情况,短路保护后不会恢复。
请问有什么相关设置改善这种情况?
Thank you Star.
But the time grid of the waveforms is 2ms, the recovery delay we set is 60s, I don't think it recovers normally.
Based on the settings, the expected behavior is, DSG FET turns off when short occur, after 60s, if the short circuit condition is still present, DSG FET turns off again, until 5 times, the DSG GET is latched off. Am I right?
While known form the pic I posted, DSG FET recovers in about 6ms after short protection. Is it possible that the firmware turns on DSG FET by mistake when exitting sleep mode?
Thanks.
