VCC电压<SRN 0.5就会进入sleep mode,
只有电池供电不表示VCC没有电压,VCC can be supplied either from the battery or the adapter
STAT1和STAT2的状态都是OFF 可能处于以下状态
Charge suspend, timer fault, overv oltage, sleep mode, battery absent
