5557.BQ3060如何手动用指令将电池进入SHUTDOWN mode.docx0451.BQ3060如何手动用指令将电池进入SHUTDOWN mode.docx
您好:电池电压15.2V(4S1P)无上锁状态下在ManufacturerAccess 下command Shutdown(0x0010),输入后电池无法进入Shutdown mode
Operation Cfg C 0007
[Power(Power)]
Flash Update OK Voltage = 7500
Shutdown Voltage = 11400
Shutdown Time = 10
Cell Shutdown Voltage = 2850
Cell Shutdown Time = 10
AFE Shutdown Voltage = 3000
Sleep Current = 10
Bus Low Time = 5
Cal Inhibit Temp Low = 5.0
Cal Inhibit Temp High = 45.0
Sleep Voltage Time = 5
Sleep Current Time = 20
Wake Current Reg = 03
[Header]
bq EVSW Version = 0.9.59
DeviceName = bq3060 v0.14
Time = 2020-12-15 10:09:12
[Voltage(1st Level Safety)]
LT COV Threshold = 0
LT COV Recovery = 0
ST COV Threshold = 0
ST COV Recovery = 0
HT COV Threshold = 0
HT COV Recovery = 0
CUV Threshold = 0
CUV Recovery = 0
[Current(1st Level Safety)]
OC (1st Tier) Chg = 0
OC (1st Tier) Chg Time = 0
OC Chg Recovery = 0
OC (1st Tier) Dsg = 0
OC (1st Tier) Dsg Time = 0
OC Dsg Recovery = 0
Current Recovery Time = 0
AFE OC Dsg = 00
AFE OC Dsg Time = 00
AFE OC Dsg Recovery = 0
AFE SC Chg Cfg = 00
AFE SC Dsg Cfg = 00
AFE SC Recovery = 0
[Temperature(1st Level Safety)]
Over Temp Chg = 0.0
OT Chg Time = 0
OT Chg Recovery = 0.0
Over Temp Dsg = 0.0
OT Dsg Time = 0
OT Dsg Recovery = 0.0
[Voltage(2nd Level Safety)]
LT SOV Threshold = 0
ST SOV Threshold = 0
HT SOV Threshold = 0
SOV Time = 0
PF SOV Fuse Blow Delay = 0
Cell Imbalance Current = 0
Cell Imbalance Fail Voltage = 0
Cell Imbalance Time = 0
Battery Rest Time = 0
Min CIM-check voltage = 0
PFIN Detect Time = 0
[Current(2nd Level Safety)]
SOC Chg = 0
SOC Chg Time = 0
SOC Dsg = 0
SOC Dsg Time = 0
[Temperature(2nd Level Safety)]
SOT Chg = 0.0
SOT Chg Time = 0
SOT Dsg = 0.0
SOT Dsg Time = 0
Open Thermistor = 0.0
Open Time = 0
[FET Verification(2nd Level Safety)]
FET Fail Limit = 0
FET Fail Time = 0
[AFE Verification(2nd Level Safety)]
AFE Check Time = 0
AFE Fail Limit = 0
AFE Fail Recovery Time = 0
AFE Init Retry Limit = 0
AFE Init Limit = 0
[Charge Temperature Cfg(Charge Control)]
JT1 = 0.0
JT2 = 0.0
JT2a = 0.0
JT3 = 0.0
JT4 = 0.0
Temp Hys = 0.0
[Pre-Charge Cfg(Charge Control)]
Pre-chg Current = 0
Pre-chg Voltage = 0
Recovery Voltage = 0
[Charge Cfg(Charge Control)]
LT Chg Voltage = 0
LT Chg Current1 = 0
LT Chg Current2 = 0
LT Chg Current3 = 0
ST1 Chg Voltage = 0
ST1 Chg Current1 = 0
ST1 Chg Current2 = 0
ST1 Chg Current3 = 0
ST2 Chg Voltage = 0
ST2 Chg Current1 = 0
ST2 Chg Current2 = 0
ST2 Chg Current3 = 0
HT Chg Voltage = 0
HT Chg Current1 = 0
HT Chg Current2 = 0
HT Chg Current3 = 0
Cell Voltage Threshold1 = 0
Cell Voltage Threshold2 = 0
Cell Voltage Thresh Hys = 0
[Termination Cfg(Charge Control)]
Taper Current = 0
Taper Voltage = 0
Current Taper Window = 0
TCA Set % = 0
TCA Clear % = 0
FC Set % = 0
FC Clear % = 0
[Cell Balancing Cfg(Charge Control)]
Cell Balance Threshold = 0
Cell Balance Window = 0
Cell Balance Min = 0
Cell Balance Interval = 0
[Charging Faults(Charge Control)]
Over Charging Voltage = 0
Over Charging Volt Time = 0
Over Charging Current = 0
Over Charging Curr Time = 0
Over Charging Curr Recov = 0
Depleted Voltage = 0
Depleted Voltage Time = 0
Depleted Recovery = 0
Over Charge Capacity = 0
Over Charge Recovery = 0
FC-MTO = 0
PC-MTO = 0
Charge Fault Cfg = 00
[Data(SBS Configuration)]
Rem Cap Alarm = 0
Rem Energy Alarm = 0
Rem Time Alarm = 0
Init Battery Mode = 0000
Design Voltage = 0
Spec Info = 0000
