UCC25600 LLC空载电压稳不住..请问有何建议
IC进入burst mode了,但电压还稳不住
I found that due to working in the burst mode, the energy of the aux_Vcc supplied by auxilliy wiring is not enough to keep Vcc stable.
it seem that it is regardless of Loop gain.
改变供电方式,
轻载时候由PFC 那边的VCC供电于PWM ic,可以解决空载下(进入burst mode)输出电压不稳问题..
