关于VOK的问题
VOK从未置位,这是正常的吗?如果不正常,VOK会在何时置位
  • 您好,The [VOK] flag indicates the last OCV reading is qualified for the QMax
    update. The [VOK] is set when charge or discharge starts. It is cleared when the QMax update occurs,
    when the offset error for a QMax disqualification is met, or when there is a full reset.
