Part Number: BQ27Z561EVM-011
Other Parts Discussed in Thread: BQSTUDIO
use bq27z561EVM-011 in bqStudio, in Technical Documents of sluuc54b , at the page 99 , the document shows the command example , I follow the example to write the command in 0x40A9, want to change the Manufacture data,When I write the data and read the address data, I find that the data has not been modified.
Attached is the operation record .The original data is 5221, which needs to be modified to 52B1
