最近BQ76PL455A-Q1涨价太贵了,都被车企买走了。打算用BQ76PL455A在非车规场合用。
请问两种芯片可以使用同一套代码吗?我看内部的寄存器映射是一样的。
Thanks in advance.
Thanks in advance.
您好,从功能(特别是在软件功能方面)的角度来看,是同一个设备.
From device perspective, it is similar specs and can abide by the datasheet specs, however there are some internal quality/reflow/auto tests that do not get completed on the non Q1 devices to be aware of otherwise it is a similar device.
