Part Number: LM5122
Hi
I would like to design multi phase boost application, here is design requirement,
The boost input voltage is 4.2V~9.6V and output is 12.3V/62A. may I use the LM5122 that configuration is six-phase daisy chain, or any better solution could be use ? Thanks.
