编译的过程中报Description Resource Path Location Type
mklib: gmake error during rtsv4_A_be_tiarm9.lib build null: mklib: gmake error during rtsv4_A_be_tiarm9.lib build DSP_PROJECT1 C/C++ Problem
Hi
关于UCD3138程序,建议你直接到美国E2E网站上咨询,因为以前TI程序只能通过签保密协议才能拿到,包括评估板(现在有些在官网有),我们也都是没有程序的,而且没有相关程序的说明文档。
https://e2e.ti.com/
<Linking>
warning #10366-D: automatic library build: using library "E:\Program Files (x86)\ccs8\ccsv8\tools\compiler\ti-cgt-arm_5.2.9\lib\rtsv4_T_be_tiarm9.lib" for the first time, so it must be built. This may take a few minutes.
'e:/program' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
>> ERROR: mklib: gmake error during rtsv4_T_be_tiarm9.lib build
warning #10207-D: automatic RTS selection: resolving index library "libc.a" to "rtsv4_T_be_tiarm9.lib", but "rtsv4_T_be_tiarm9.lib" was not found
