Other Parts Discussed in Thread: ULQ2003A-Q1
请问下大神,ULQ2004AN 可以直接用ULQ2003AN替代使用吗?
Hi
不能直接替代使用: The ULQ2003A-Q1 has a 2.7-kΩ series base resistor for each Darlington pair, for operation directly with TTL or 5-V CMOS devices. The ULQ2004A-Q1 has a 10.5-kΩ series base resistor to allow operation directly from CMOS devices that use supply voltages of 6 V to 15 V.
两个芯片差异还是很大的,你可以比较一下参数表: www.ti.com.cn/.../ulq2004a-q1.pdf
