Other Parts Discussed in Thread: BQSTUDIO, GPCRB
Hi Ti工程师,
BQ40Z80做低温补偿,得到的GPC报告需要怎么处理,烧录里面的gg文件就好了吗?还是也需要烧录chemdat12_ID497?
您好,需要烧录Chemdat12,请参考下面的内容:
The tool will produce a chemdat12 or *.chem file independent of the initial *.gg.csv file. Chemdat12 must be programmed using bqStudio chemistry GUI before the *.gg.csv file, in order to provide both improved resistance temperature compensation and learned values
您好,请参考下面链接的内容
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/874153/bq27742-g1-the-report-of-gpcrb-include-files-chemdat12_id2166-gg_out-csv-gpc_report-xt-and-so-on-which-files-promgramed-into-bq27742-by-ev2400?tisearch=e2e-sitesearch&keymatch=GPCRB%252520report#
