Other Parts Discussed in Thread: UCD3138
报错信息:
Description Resource Path Location Type
#1559 Interrupt handlers must be compiled in ARM mode standard_interrupt.c /UCD3138_LLC_HB line 703 C/C++ Problem
当我把interrupts.c中断函数改成32位编译的时候,居然不报错了,这是怎么原理??
修改的32位编译如图右所示。
还有这个警告怎么处理?
警告信息:
This project is currently in 'manual' Parser Preprocessing mode - no dependency graph is automatically generated. This mode should only be temporarily used to generate various pre-processor listing files. Please switch the Parser Preprocessing mode back to 'automatic' for you regular builds. UCD3138_LLC_HB properties Problem.
