Following is the LM25069‘s circuit sch and the computing process of R1 and R2. The voltage of VCC_SYS is 4.97V.The value of R1 and R2 is 15k and 5.1k. The UVLO's voltage should be 1.26V, but the actual measured value is 1.117V.
Is there any problems in the circuit design?
Thanks!
