Part Number: BQ78350-R1
Other Parts Discussed in Thread: BQ78350
我们使用Battery Management Studio 通过命令CHEM_ID(0x6),读取BQ78350-R1的化学ID为0x1210。但是这个参数不对,请问如何修改这个化学ID。
您好我们已收到您的问题并升级到英文论坛,如有答复将尽快回复您。谢谢!
您好,您的问题在英文论坛已有工程师跟进,请持续关注:
BQ78350 configures those registers to appropriate values, so that when one of the four batteries is lower than 2.5V, BQ78350 does not supply power to the outside, so as to protect the battery 。
"Set CUV threshold to the desired value. I recommend that you read through the Protections documentation in the TRM."
您是说这个是吗?
