BQ34Z110: 单片机与BQ34Z110的IIC通信问题
Part Number: BQ34Z110
代码如下,发了命令,一直读不到数据
#include <STC8.H>
#include "intrins.h"
#define I2CCFG (*(unsigned char volatile xdata *)0xfe80)
#define I2CMSCR (*(unsigned char volatile xdata *)0xfe81)
#define I2CMSST (*(unsigned char volatile xdata *)0xfe82)
#define I2CSLCR (*(unsigned char volatile xdata *)0xfe83)
#define I2CSLST (*(unsigned char volatile xdata *)0xfe84)
#define I2CSLADR (*(unsigned char volatile xdata *)0xfe85)
#define I2CTXD (*(unsigned char volatile xdata *)0xfe86)
#define I2CRXD (*(unsigned char volatile xdata *)0xfe87)
sbit SDA = P5^4;
sbit SCL = P5^5;
void Wait()
while (!(I2CMSST & 0x40));
I2CMSST &= ~0x40;
void Start()
I2CMSCR = 0x01; //发送开始信号
Wait();
void SendData(char dat)
I2CTXD = dat; //写数据到数据缓冲区
I2CMSCR = 0x02; //发送SEND命令
Wait();
void RecvACK()
I2CMSCR = 0x03; //发送读ACK命令
Wait();
char RecvData()
I2CMSCR = 0x04; //发送RECV命令
Wait();
return I2CRXD;
void SendACK()
I2CMSST = 0x00; //发送ACK命令
I2CMSCR = 0x05;
Wait();
void SendNAK()
I2CMSST = 0x01; //发送NAK命令
I2CMSCR = 0x05;
Wait();
void Stop()
I2CMSCR = 0x06; //发送STOP命令
Wait();
void Delay()
int i;
for (i=0; i<3000; i++)
_nop_();
_nop_();
_nop_();
_nop_();
void main()
unsigned char i,j;
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
P_SW2 = 0x80;
I2CCFG = 0xe0; //使能I2C主机模式
I2CMSST = 0x00;
Start();
SendData(0xaa); //发从机设备地址+写命令
RecvACK();
SendData(0x04); //发查电池剩余电量命令
RecvACK();
Stop(); //发停止命令
Delay(); //等待写入数据
Start(); //
SendData(0xab); //发从机设备地址+读命令
RecvACK();
i= RecvData(); //读返回结果
SendACK();
j= RecvData();
SendACK();
Stop();
P_SW2 = 0x00;
