BQ34Z100数据能读,,但是数据写不进去,请问这是为什么
你好,这个现象是出现在EVSW还是自己编写的程序?如果是自己的程序,可以用示波器抓取EVSW的写命令波形进行对比。
I tried the bqEVSW0.9.90 software to write the configuration section of DATA Flash and met the same issue. After using "writes all" function several times, the bqEVSW cannot write any data successfully.
Could you answer why and how to solve it?
Best regards,
I use EV2300 and evaluation software together.
请采用TI最新的BQSTUDIO软件进行操作看一下?目前TI的BMS方案基本上统一到这个软件里面了。
