Part Number: TPS7B4250-Q1
您好:
TPS7B4250QDBVRQ1 客户测试发现与数据不符,但我们能确定货是正规渠道的,原装正品,请问为什么会出现这种情况呢?
After electrical test, we found there are inconsistence between the test result and datasheet. We found pin 2 is open circuit in the curve trace.
Please help to ask for MFG explanation about why pin 2 is not connected to ground and not connected to pin 5.
Please see the attached pictures.
Test Condition:
when one pin was tested, all the other pins are grounded.
Range: from -1.5v to +1.5v
Sampling point : 100
下面是此型号的照片
