Other Parts Discussed in Thread: TPS2540,
TPS2540 was used for the design completely. But cause of the delivery cycle, We need to make sure that TPS2546 can P2P replace TPS2540.
There is a different between them as PIN9 define. If the device PIN9(STATUS) open-drain output can be NC?
